ahh...http://www.autodesk.com/products/screencast/overview
Thanks.
It is not about slowness. I have a computer that was top of the line about 2 years ago. It is a "BUG". The GUI acts differently and it is inconsistent between a "Form" and regular "Create" and in software development that is a "no-no". It causes the interface to be unpredictable and make it more difficult to understand and learn.
It is way to easy to pass this "dimension" screen in a "Form" with so much as a single carriage return, after doing a rather reasonable operation, entering the circumference. If you do what I describe, you NEVER see the dimension screen. However, do the same thing in a regular create draw of a cylinder and there is no problem. It works great. Hit the same carriage return after a dimension and up comes the additional properties dialog. Worse, after doing that in a "Form", you are "DONE". You must undo and start over. However, in a regular draw, you can go back and re-edit the properties.
You don't need a screencast. It is easy to reproduce.
- Click on Form
- Choose Create> Cylinder
- Choose Plane
- Drag circle location
- Enter the dimension in the box
- Hit carriage return twice to enter the dimension and then to go to the next step
Repeat for a non-form and something entirely different happens.
Result = two entirely DIFFERENT THINGS happen...and the screen that is lost in the Form cylinder creation is one of the most important for that object.
Now that I understand what is going on, I can work around it, but new users see problems like this as just pure "frustration" because they are trying to learn the interface and learning is about the same things happen over and over again and forming that pattern in our brain that we call "learned". So to a new user...it makes it look like something is broken.
