Message 1 of 10
02:09 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Fusion 360 to draw table tops for a project I am working on. The table top I am currently working on has 1" radius corners on it. I have several 1" radius table tops to draw in various sizes. In the example image below I have drawn a 38"x48" top with the corners rounded centered on the middle axis point. I would like to then be able to change the dimensions of the top and have the sketch stay centered on the middle point. But currently, when I change the width the sketch scales out to the right like in the second image. Is there a way to keep the sketch centered and scale out from the middle?
