Why can I not use the "S" key as a shortcut for the sweep command? When I try and set the shortcut for sweep command as S I get a message saying it is reserved and can not be used as a shortcut.
Solved by whittakerdw. Go to Solution.
Solved by shabbir.abdulhussein. Go to Solution.
Looking at the User Guides (Help documentation), it seems to be that the "S" key is reserved for the "Toolbox" command.
See more on shortcuts here: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F0491540-0324-470A-B651-2238D0EFAC30
The s key is used for the shortcut toolbox. There are a few keys, such as ctrl+z and ctrl+s, that cannot be used since they are already programmed to undo and save, respectively. If you are set on using the s key for the sweep shortcut, then you could use alt+s as the shortcut. Since S is already set for toolbox it cannot be used, but alt+S can be used. Here is a link with information about what keys can and can't be used and why they can't be. https://forums.autodesk.com/t5/fusion-360-design-validate/update-customizable-keyboard-shortcuts/m-p...
Thank you both. That makes sense as to why it can't be used. I was unaware of the shortcut toolbox @whittakerdw mentioned. That will be really helpful to use. @shabbir.abdulhussein thank you for the link. That is really helpful as well.
