REQUEST: Part import orientation
When importing / opening a converted Fusion 360 model. Could there be an auto pop dialog asking if you would like to set the home orientation on first open? The orientation doesn't ever seem to be correct.
Thanks.
Crag.
masa.minohara
Hi Crag,
Thank you for posting! Unfortunately Fusion 360 doesn't show a dialogue box for you to set the orientation. As far as I know Fusion keeps the original orientation of the imported model. Could you check the following? If these don't help, could you let me know the steps to reproduce the issue? I would like to take a closer look at the issue.
1. Turn on the display of the origin in the browser and check if the orientation of the imported model is correct
2. in the Preference, set the Default modeling orientation to "Z up"
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
