Rendering Problem, colour not showing correctly
Hi guys has anybody seen this happen before? Looks as it should in the rendering environment, however when the render is complete it comes out like this : With the strange grey streaks down the oak door on the left?
Much appreciated
TrippyLighting
We'd need to see the model. I suspect that the left door has duplicate geometry that is Z-Fighting.
Ahh ok heres the link let me know what your thoughts may be! Any criticism
on my modelling techniques much appreciated too
https://a360.co/2IhkpwJ
TrippyLighting
Ha, this is an interesting one 😉
You applied a Mahagony material to the door assembly and then at a lower level the Oak - Glossy texture to the left door only. I've not been able to find a way to delete a texture from an individual component so you'll have to "Unassign and delete" both textures in the Appearance panel and then re-apply to each individual door, but not the door assembly.
Ah I see! So its trying to render two materials onto the same bodies and
doesn't know which one to take precedent ?
TrippyLighting
Yep
