I am looking to model a 1.250 X 11.5 NPT
I modeled the taper required for the major Diameter.
But the "Create Thread" doesn't seem to have this thread I need.
Is there a work around to model this thread?
Solved by HughesTooling. Go to Solution.
There are no modeled tapered threads at the moment. Your only option is to use coil and construct it, bit fiddly with a taper thread. What do you need it modeled for, 3d printing?
Mark
Mark Hughes
Owner, Hughes Tooling
My customer likes me to render the models for his advertisements.
Cool...
Thanks I will play with the Coil feature and see if I can duplicate what I need.
THANKS AGAIN!!!!
