Hello people
In those recent days I've been trying many ways to export a fusion360 model with it's dimensions rendered together with the model. I want, then, to import it to a certain program and have the dimensions from Fusion360 kept. Is there any way to do this?
That depends on the format- some don't include scale data; in such cases, consider including a unit block in the design- say, a cubic inch or centimeter -to use for adjusting the model scale in the target program.
Let me give some more informations then, the target program is enTiTi (AR program) and as a matter of tool plethora, it is very limited... the best I can do there is put 3d text manually on each model but it is too inefficient and time-wasting.
Now about the formats. I am not sure which of those are convertable via Fusion360 but I use .fbx format. Some more formats are Collada (.dae) OBJ(.obj) and STL(.stl)
