Rendering error
Rendering error
BartsGarage
Message 1 of 27
Rendering error
BartsGarage
Hi!
I have huge trouble with rendering my model on Fusion 360.
"Your rendering could not be rendered because an error occurred. Please check your file and try again."
The model is 50MB IGES import with many elements. I have deleted all previous materials (I thought it was caused by missing maps) but still the same. Could be caused by large model size? How to deal with it?
Replies (26)
Message 21 of 27
I am getting a similar error message but mine says
"The current design contains imported materials, which are not supported for local rendering at this time.  Please replace them or use cloud rendering."
I don't see a way in fusion to find the items that have unsupported materials.  I even tried selecting the entire assembly and changing the appearance to a material in the fusion library.  I did that and even though the entire assembly is changed to a fusion material I still get the same error message.
Message 22 of 27
Hello!
I have the same msg "Your rendering could not be rendered because an error occurred. Please check your file and try again."
and also I can't render in canvas too. Any render for any way :/!
H E L P!
Message 23 of 27
lichtzeichenanlage
I had the same problem. I could fix it by exporting the design into the cloud. Working from the new design worked just fin. The downside is, that I lost previous versions. In my case it  was okay, but your requirements might differ.
Message 24 of 27
Well I found a solution!
I had cloud/canvas render problems and the solution was:
Preferences / and select "Normal settings" in Render-Material-Graphics tabs.
Change SIMPLE SETTINGS to NORMAL SETTINGS.
Good luck!
Message 25 of 27
Thanks mate! It works too :)!
Well.. 2 Solutions at the moment YEY o/!
Message 26 of 27
Hi! I have a similar problem. Whenever I start cloud rendering to a video, it shows this "Your rendering could not be rendered because an error occurred." Cloud rendering an image is fine but I need it to be a video for rendering motion study. What should I do?
Message 27 of 27
chummarkrony
Observer
Observer
I am facing the same issue. How can  i solve it ?
i am able to do local rendering but not cloud rendering.
