project cut edge
project cut edge
ah.fathy
Message 1 of 12
project cut edge
ah.fathy
project cut edge
Replies (11)
Message 2 of 12
whunter
You're not going to get the response you hoped for with that post.
Win 10 Pro, ZBook 15 G2, South Africa.
Please mark this as Solved if it answered your question, other people may find it useful too.
Message 3 of 12
TheCADWhisperer
Message 4 of 12
whunter
Then again, maybe you will...
By note that it takes a CAD Whisperer to resolve this!
Message 5 of 12
TrippyLighting
No, it does not 😉
However, my personal approach to such post is that I will not even attempt to help if I can see that the OP makes no attempt or effort to explain.
If you want to be helped, make at least some effort to show that you deserve it!
Message 6 of 12
ah.fathy
i mention the whole problem in other post i'll share here
i wrote this post while i was trying to do some work
i'm really sorry if you see this rude from me
thanks and best regards
Message 7 of 12
TrippyLighting
You did post an idea in the idea station requesting some faeture present in Autodesk Inventor.
Without you providing more details it is impossible to help. My suspiciaon is that the feature you requested is not really needed and you simpoly do not yet have enough expreince in Fusion 360 to solve the problem.
That's what we usually help with here on the Forum 😉
Message 8 of 12
HughesTooling
I think what he's asking for is the ability to project an edge if you are using Slice or a Section Analysis and I think that would be quite useful. He added a bit more info in the Ideastation.
Here's an example as well with slice activated it would be nice if you could project the edges. You can sort of use intersect but that can project curves you might not want.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 9 of 12
HughesTooling
This is probably quite a good idea but I don't think it'll get many votes because the description on the Ideastation is so bad, I'm not sure whether to make the Idea again with some pictures and a better explanation.
Mark
Mark Hughes
Message 10 of 12
TrippyLighting
That would probably be great.
I assume that @ah.fathy in not a native english speaker and it would be grea if you could help out. It'll have my vote.
Message 11 of 12
ah.fathy
you are right to make slice on part it must have sketch on this pln and i need to project some edges to make coincident or any relation with the inner surface and now i cann't may be i have somerthing wrong but i tried many times to make constrains with inner surfaces and i cann't
Message 12 of 12
ah.fathy
Now i found this solved and i can project cut edges by Project\Intersect and it really done may be this was in yesterday update and it solved this issue
anyway i want to thank everyone tried to help me in this isue
