project cut edge
project cut edge
Dear Sir when i used to built parts i have to project cut edges to constrain the lines or circles to the inner surface and i couldn't do this as i couldn't project the internal surface or project the cut edge which is very very helpful in inventor you shall check this as i think it's very very important in building parts on each other thanks and best regards
4 Comments
ah.fathy
when i try to constraint a line with the internal profile i found its very difficult
this drawing is for cylindrical shape generated by revolve and i want to create new part related to the internal profile so i have to project the internal profile and draw the lines constrained with this profile and simply i couldn't make this connection
So i think the geniuos button on inventor called project cut edges solve all this
falteceurope
I cant believe this has taken so long to implement.
It must be a requirement for many people.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
