CAM > Setup > Stock Offset - User frustration with excess centering
For CAM users learning about the world of subtractive manufacturing understanding stock offsets is CRITICAL.
Most users measure and know their source material - in my case a simple 2x4 piece of lumber (1.5 x 3.5").
I created my model to mill most of the top .5" off the board (with the escpetion of some lettering not shown in the picture).
In choosing my CAM > SetUp I get prompted for a Model Position offset relative to the stock. I set the Z height and choose the model position to "Offset from Bottom" but I end up with the offset centering because of the default value.
It would make more sense if the Offset value was set to ZERO so the model position would be honored. This would give most people what they are looking for.  Most CNC users using a 2.5 axis machine the zero the z axis from the bottom and mill from the top.
3 Comments
kb9ydn
99.9% of the time I offset from the top and not the bottom.  Smiley Wink
But yeah, it would be nice if it defaulted to a zero value (instead of centering) when either offset is selected.
C|
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
