Render size
Render size
Message 1 of 11
Render size
I was just wondering if there's a way to increase the resolution of screenshot renders taken as mine does not go further that 800x391 which is very blurry when scaled up.
Arran
Replies (10)
Message 2 of 11
lucasproko
Hey @Anonymous,
When you use the "Capture Image" command during an "In Canvas Render" it limits the resolution to the current resolution of your window. Thus, if you'd like to get larger resolution renders, you'll have to use the Local and Cloud render options which go up to a 4,000 x 4,000 pixel resolution.
Let me know if this is suitable for your workflows, or if you have any further questions!
Lucas
Lucas Prokopiak
Fusion 360 Product Manager (Sketch/Model)
Message 3 of 11
Thank you that works perfectly 🙂
Message 4 of 11
Any reason the render size is limited to 4000 pixels? I can't see the harm of removing the limits if I am willing to do a local render and leave my computer on for days.
Message 5 of 11
lucasproko
@Anonymous - There's a couple small detailed reasons why we chose this resolution at the beginning, but there is nothing technically limiting us from expanding the size moving forward. That being said, it would still require work to make the changes, and so far this issue hasn't boiled to the top of our priorities. I would encourage you to cast a vote for the related Idea Station post linked below to help us weigh it against other projects.
https://forums.autodesk.com/t5/fusion-360-ideastation/render-image-maximum-size/idi-p/7514862
Lucas Prokopiak
Message 6 of 11
I have the problem that when i try to render a product it keep saving submitting is this good or not?
Message 7 of 11
lucasproko
@Anonymous - This is expected behavior if you have changed anything in your model such as the Appearances, whether certain bodies are turned on/off, or if you have edited the Scene Settings. That being said, if no changes have been made to your model, you can continue to create new renderings of the same saved Version.
Lucas Prokopiak
Message 8 of 11
I have changed the appearance of the model but it keeps saying submitting this took 3 hours than i cancelled the render can you help me with that?
Message 9 of 11
Please increase the size limit from 4000 px. Today I needed a render with 8000px width for an outdoor.
At least for the local render.
Message 10 of 11
mavigogun
Your only recourse was previously addressed:
@lucasproko wrote:
*snip* ...this issue hasn't boiled to the top of our priorities. I would encourage you to cast a vote for the related Idea Station post linked below to help us weigh it against other projects.
Message 11 of 11
Yes, I had already done that.
