Render Shadow with Pure White Background
craigfoo
craigfoo
I have a model I want to render with a pure white background but I also want the shadow to show up. It seems that the shadow only appears when using an environment vs. using a solid color. Is there a way to choose a solid color and use the shadow as well?
I have no issue with shadow and white background.
PhilProcarioJr
@craigfoo
When you save out your image, is that when the shadow is not showing up or is it never there?
Phil Procario Jr.
Owner, Laser & CNC Creations
craigfoo
I found what I was doing wrong. My environment was using "Grid Light" which wasn't giving a great shadow. I changed the "Cool Light" and I have a nice shadow now.
EDIT: Spoke too soon, the shadow isn't showing in the final render.
EDIT AGAIN: Shadow might be there but it's very very faint.
was this ever solved I have the same issue I see the shadow in the render window but when I render and download image no Shadow.
AmirLavi001
same issue
e11828334
How did you do it? I am having the same troubles as the others.
