Render on grass-like material
Nickduino
Nickduino
I'm designing outdoor furniture and I'd like to render them on a patch of grass. It doesn't need to be too fancy/realistic, just something green and fuzzy.
What material would you use for the grass?
aliobidi
Hi ,
you should to download material maps from the web and use it
hamid.sh.
I am guessing you're not exactly looking for material but for HDRI maps to set as your environment background. For this you need to first change scene settings to enable environment background instead of solid color. Fusion has some backgrounds in its library. If none matches your requirement you can download from external sources. Check out this post in which some good resources are mentioned in the replies.
Hamid
Nickduino
I'm looking for something quick and dirty: just a patch of grass, not a full-fledged and realistic environment
hamid.sh.
Then perhaps "Field" scene which is included with Fusion (just need a one time download by that small button) works for you.
Hamid
Nickduino
I launched the download half an hour ago, I'd still not there. I'll probably have to restart Fusion or something.
But I fear it will distract from the part I'm rendering, I would still like something simpler better.
