Removing Overlaping lines in sketch
I usually convert hundreds of photos into sketches. Therefore in every photo, I use different commands like line, spline, arc, etc. I am facing a problem when I try to select them all at once and offset it gives me an error and when I look one of them may be having overlapping lines. then I have to look through each of them individually and that is **** tiring. Do you have any kind of suggestion?
Marco.Takx
Hi @Anonymous,
Within Fusion360 there is no option to do that.
If you have AutoCAD you can use OVERKILL
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
