how to join or align bodies in my design?
Message 1 of 17
Here is a part of my design :
The blue bodies are correctly joined to the rail. I just designed the yellow bodies but they are too high. I just want them to go down a little they need to be attached to the rail too.
I tried a lot of things with the joint tool but i wasn't able to do what i want. I tried the move tool to move down the yellow part and then i used rigid group with the rail but it's not really accurate.
Can someone explain me how i can do that please.
Unfortuantely i cannot share my f3d because i have a lot of things already in it...
Replies (16)
Message 2 of 17
wmhazzard
Have you tried the align command?
Message 3 of 17
I tried, but maybe i'm using it wrong. Because each time a tried i have my yellow bodies who move in two direction. I just want them to go down (Z axis for me). I don't want them to move allong X or Y axis. In these dimensions my bodies are in the good place.
Message 4 of 17
g-andresen
Is there a reason you don't use joints?
If you haven't worked with them before, look at them, it's worth it!
günther
Message 5 of 17
I work a lot with them! But i don't know how to use them for doing what i want to do know. Each time i tried with a join it end up with my yellow bodies completely disturbed.
Message 6 of 17
jhackney1972
How about sharing your design so the forum users can help you with your issue.  A Screencast using your model will probably get you over your hump.  Only share what you have already shown.
John Hackney, Retired
Message 7 of 17
Ok here is à f3d file with my design. I know that i have a warning on a sketch but that's because i delete a lot of things before. At least you have a file you can work with.
Message 8 of 17
jhackney1972
So a couple of Pin-Slot Joints on each yellow bracket can position in on the slots in the rail and allow you to move them anywhere you desire.  I did not mention it in the Screencast but I had to ground the horizontal rail so I could move the joint.  Your model, modified, is attached with a different name.
Message 9 of 17
jhackney1972
Forgot the model, getting old!
Message 10 of 17
I don't want them to be able to move. Their positions are fixed by the sketch. I just want them to be correctly attached to the rail. If i want to move them i'll go modify my sketch.
Edit : And if possible i don't want to use offset. because if i change some dimension i'll have to come back to my joint and modify it too.
Message 11 of 17
jhackney1972
Nothing like defining your problem in your post!  As it is you can position the bracket in the correct position and "lock" the joint and it will be stationary.  The only offset I used was the depth of the slot, which is probably not going to change.  I will look at it again, which sketch are you speaking of?
Message 12 of 17
In this sketch :
As i said since the begining, i just want the yellow bodies to go down and to be fixed onto the rail. Maybe i didn't explain it right. I'm sorry i'm not native English speaking.
Message 13 of 17
jhackney1972
What you probably want to use is what I call an Assembly Sketch.  This sketch is used as a "locator" for a Rigid joint between the bracket hole and a point in the assembly sketch.  The bracket is fixed and you can move it anywhere along the length of the rail using the assembly sketch dimension.  Screencast is attached as well as the model.  I labeled the assembly sketch so you can find it.  I only did one bracket.
Message 14 of 17
jhackney1972
By the way, I chose the four hole side of the bracket, you can choose any side you want for the assembly sketch.
Message 15 of 17
May i used the sketch i already did as an Assembly Sketch? If yes your solution is correct but i don't know how to apply it with my actual sketch. If i have to add a new sketch like you did it's not what i want.
Message 16 of 17
jhackney1972
No, you cannot use that particular sketch because is is a sketch under a component.  If you will notice my assembly sketch is in the assembly, not below any component or body.  You can create one very similar but it has to be in the assembly.
Message 17 of 17
TrippyLighting
Let me first say that your English is perfectly OK and you also explained well what you want to do. You basically designed these parts in place and now want to use a rigid group join to "lock" all the parts into place.
The reason that does not work as expected is that you have not included all the necessary origins in that rigid group joint.
