Select all edges/vertices of a sketch face
yuriy.tymchuk
yuriy.tymchuk
Hi, is it possible to select all the edges and/or vertices of a "face" in a sketch? By "face" I mean the inclosed area which Fusin360 colors in light blue.
Often I need to just select all the edges of such area (to offset) or I want to delete such area. And it's super-easy to select such face, but instead I need to select all the edges and vertices and this is a pain in the neck…
Marco.Takx
Hi @yuriy.tymchuk,
Double click on the same line and the whole loop will be selected.
Hope this helps you further.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
JHRendon
Something like this? Double click.
yuriy.tymchuk
I read about the double click somewhere already but it didn't work for me. Now I tried again and indeed that works on a shape that I create with lines. But when I try to do this with a shape imported from a DXF file nothing happens. Does this have to do something with the import? Because otherwise, I can do other operations one can do with enclosed shapes (like extruding)
Marco.Takx
Hi @yuriy.tymchuk,
This shoot also works for DXF imported sketches.
I think the problem is that the end point's aren't constraint perfectly.
Or the lines are not created on the same layer.
Crap in is crap out 😉
Marco Takx
