removing a chunk of body that is 6 sided sketched.
lg44logistics
Observer
lg44logistics
Observer
Observer
I created a Metal square tube body.  I sketched an area on the top of my model. The sketch is for chunks of the body that I want to cut out. Can't figure out how to remove one side - the split body and split face cuts the Whole body.  Also I can't select the inside lower square.
Replies (11)
jscott6SWZG
Did you try an extrude.  Select closed area. Blue on sketch.  Then extrude however deep you want select cut and object to cut and done
TheCADWhisperer
Are the sketch and body in the same component?
Why are you using Fixed geometry?
Why are these dimensions repeated?
What measuring instrument will be used to measure 2.4074854?
What manufacturing process will be used to get 7 decimal places?
I think there is an easier technique - but it will require starting over.
Why repeat the same geometry?
@lg44logistics
Let me know when you are ready to start over.
TheCADWhisperer
@lg44logistics
I would have expected a lot of questions after my last post?
Where did you go?
TheCADWhisperer
Not sure what happened to the OP, but for those who come along looking for tips on Frame Design see the Attached file that is fully defined sketches (easy to edit) with simple dimensions that the shop floor fabricator/welder can easily measure.
If the OP returns we can look at the cuts at the top of the Corner Braces (which will similarly be simply defined in a way that the shop floor fabricator/welder would work).
Edit: Not sure where the OP came up with the 20.351 dimension - I suspect it is a rounding error for a desired Angle of the braces as I don't think the shop floor fabricators/welders are going to be working to .001 of an inch.
TheCADWhisperer
@lg44logistics
Just took a look at the list of Parameters. Yikes!
TheCADWhisperer
@lg44logistics
Alternative - Build Envelope Technique Attached...
The opacity of the envelope can be adjusted as desired.
I normally have a keep in or keep out, sometimes a center plane envelope.
lg44logistics
Observer
Observer
Pardon me
The reason the dimensions are repeated is because I want the Corner Tubing to remain locked into their respected corners even if I make changes.
I have this problem solved and locked in place.
lg44logistics
Observer
Observer
I am a novice! This project is for my home. After I assemble the CrossFire Plasma Cutter I bought last year, the projects I have made, will be cut out. I will be teaching myself to weld.
lg44logistics
Observer
Observer
The center line was such a small sketch that I attached it to the BTM Sketch
lg44logistics
Observer
Observer
I wrote in another post under this thread that I have spent over a year and HUNDREDS of hours working on this project. With all of the problems I've had, with Thousands of deleted lines and points.
Eventually I would like to learn how to clean up the unused lines and points that are in the parameters table.
TheCADWhisperer
@lg44logistics
You should ask questions much earlier in the learning effort.
Hopefully you have not developed any bad habits that will now be difficult to overcome.
You are doing far better than most beginners - but going the long way around.
Go through the two files that I attached (especially the second one - Envelope Technique) and reproduce the steps yourself (ask questions).  When you have completed that we can move on to the cuts at the top of the tube.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
