- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there
I am transferring my PCB designs from EAGLE standalone to FUSION360. I have one design which is also used in an assembly which I want to use further. So I created the 3D PCB from within FUSION after a transfer of all my related file and had to generate a new 3D PCB connection because the current was not accepted. so I removed the broke the link in the assembly and deleted the 3D PCB. After that I added the newly created 3D PCB. all works fine only I am not able to delete the former 3D PCB file because it thinks it is still referenced by another design but if I click on the version tab in the data panel and choose the Used In tab I read "the item is not referenced in any other design"
If the item is not referenced why is it not possible to delete the item. I do not need it anymore.
