Remove surface dividing?
joergen_nilsson
Message 1 of 16
joergen_nilsson
Is it possible to remove the lines dividing the surface shown in supplement model picture, similar to the fill command in Spaceclaim?
Replies (15)
Message 2 of 16
davebYYPCU
Try Hotkey - Cntrl & 4
for the same as
Display Settings > Visual Display > Shaded.
Might help....
Message 3 of 16
joergen_nilsson
What I really want to do is to merge the surfaces together.
Message 4 of 16
TheCADWhisperer
@joergen_nilsson
How did you model the revolution - did you use Revolve or did you use Loft?
Did you use Spline or did you use Tangent Arcs?
How will you manufacture?
3D printing? Then remesh.
See Message 17 >>Remesh<<
Message 5 of 16
g-andresen
If you don't have more than 1 surface or solid in the browser, there is no reason to merge anything.
From my point of view, this is a normal display for rotated and lofted structures.
You can also see that there are no edges if you use the "Zebra Analysis" tool under "Inspect".
günther
Message 6 of 16
joergen_nilsson
Here is my model as requested.
Message 7 of 16
joergen_nilsson
Perhaps it doesn't matter for this vase model, other than just for aesthetic reason.
But lets say I prepared for FEA, then I would like to be able to merge and split surfaces as I want.
Message 8 of 16
g-andresen
As I suspected, there is nothing that could be merged.
günther
Message 9 of 16
joergen_nilsson
I don't think you understand my goal. Sorry for bad english (not my native language).
With merge I mean make two surface areas in to one common.
Like for example the two blue areas below.
Message 10 of 16
TheCADWhisperer
@joergen_nilsson
As I suspected - your Sketch1 has a Spline curve.
What is the tolerance of the manufacturing process (you never answered the question about what process you will use)?
Can you replace the Spline with Tangent Arcs?
Unfortunately tangent arcs revolve to different boundary patches (see Attached).
Message 11 of 16
g-andresen
the blue area is one surface
günther
Message 12 of 16
joergen_nilsson
Ok, but as I mentioned my question was more of a general principe and not specifically meant for this model.
Message 13 of 16
TheCADWhisperer
Multiple faces.
Message 14 of 16
g-andresen
@TheCADWhisperer wrote:
Multiple faces.
However, as you can see in the screencast, they behave like a single surface.
günther
Message 15 of 16
TheCADWhisperer
@joergen_nilsson
See Attached file.
Message 16 of 16
joergen_nilsson
Ok, thanks. To remove and replace the split surfaces is of course an option.
But still, it feels like a workaround for a missing feature in Fusion.
