Remove Part of circle
ludwig9GUSA
Message 1 of 11
ludwig9GUSA
Hello everybody,
I'm really new to Fusion360 and finished/printed my first design. But I need to remove a part of a circle that holds the construction on a wooden stick. I did it after printing with a tool, but I want to implement this to my design in Fusion. How can I remove the section of the circle (should be 90°)? I attached two Images, one of the printed Part, how it should look like and one of the current design in Fusion (both top-down view). I hope someone can help me.
Best regrads
Replies (10)
Message 2 of 11
wersy
Message 3 of 11
TheCADWhisperer
@ludwig9GUSA
There is no need to trim the sketch to get your geometry.
Message 4 of 11
g-andresen
no trim needed
(view in My Videos)
günther
Message 5 of 11
ludwig9GUSA
sorry for the late reply, but here is the f3d file
Message 6 of 11
ludwig9GUSA
Thanks for this way, unfortunatly this don't work because I already have extruded the sketch and nothing changes at the extrusion, when I follow the steps
Message 7 of 11
g-andresen
just add the profile
(view in My Videos)
günther
Message 8 of 11
etfrench
If you're in Direct Modeling mode instead of Timeline mode, simply Extrude/Cut that section from the original.
ETFrench
Message 9 of 11
ludwig9GUSA
I don't know what I'm doing wrong, but when I try to apply the Symmetry tool, I get this Error: "Failed to solve. Please try revising dimensions or constraints." What need I do to solve this?
Message 10 of 11
ludwig9GUSA
also I don't understand how you change the angle at the end with the sketch Dimension tool. If I open your file I can do ith when I long press the left mouse button, while applying the tool, but with my original file that doesn't work. What can I do so it works in my file and I could possilbe change the angle?
Message 11 of 11
g-andresen
In sketch 3, I first added 2 lines at arbitrary angles and arranged them symmetrically to a vertical line.
Then I dimensioned the angle between the lines (90 deg).
Günther
