Remove Draft keeping dependent features
manusha1980
manusha1980
Hello
In my design I have two drafts created on two surfaces. There are many dependent features that use the surfaces that results in after the draft. These features are used by other features, and the chain continues.
Now I wish to get rid of these drafts. The features that depend on the surfaces created by the drafts can use the original surfaces before the draft is applied. I am having a huge difficulty getting rid of the draft as when I suppress the feature all features in the chain are also suppressed. I tried to set the angle to zero of the draft but it does not allow that. Then I tried to create a user parameter with non zero value for the angle and use it on the drafts. It only lets me use the parameter in the first draft (why?). My plan was to set the paramter to zero later so drafts are essentially disabled.
Any suggestions?
TheCADWhisperer
@manusha1980
