regenarate feature
regenarate feature
jean-michel_legoff
regenarate feature
jean-michel_legoff
In Browser, is it possible to add a regenerate button?
I've tried to edit some parameters of a geometru thanks to the "Change Parameters" window, but when closing this window the geometry don't change...
Is it possible to do something?
Many Thanks
pierre-yves.monarque
Hi Jean-Michel
Geometry should update when parameters are modified with the change parameter window.
I joined a Gif file as an example.
If you are facing a case where geometry does not update it could be an issue with current browser Fusion 360 version.
Could you give us some more details and/or share the f3d design so that we can try to reproduce and fix.
Thanks you very much for sharing
Regards
Pierre
Pierre-Yves Monarque
Autodesk Fusion 360 Team
