Can't unfold sheet metal
Hello
Really enjoying fusion360 so far but i can't unfold my sheet metal design to show to the factory.
I get the following error message "warning the selected stationary entity is not connected to any bends" regardless of which face I select.
Am I missing something obvious?
Thanks in advance for your guidance
sanjay_jayabal
Hi @Anonymous,
If you are able to share your design, it would help very much.  If you don't want to share it here, would you be able to send me private message with a link to it?  My email is sanjay.jayabal@autodesk.com
Right click on your design in the data panel and choose "Share Public Link".  Make sure the checkbox to allow download is checked, copy the link provided and post it here or send it to me.
Best regards,
Sanjay Jayabal.
I am having the same issue, can you share the solution?  Thanks,
Cameron
JDMather
Can you File>Export and then Attach your *.f3d file here?
having same issue
