Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Red Mark on sketch in browser
2 REPLIES 2
1232 Views, 2 Replies
What does the red mark on the sketch mean? It disappears when I remove a dimmension, but without that dimmension I believe the sketch is underconstrained (some of the lines are colored blue).   I have the preview feature "color sketch geometry based on constraint status" turned on.
See the attached screen shot for the red mark:
Also, are the colors that the constraint coloring uses documented anywhere?
Thanks.
    --- Carl
2 REPLIES 2
jeff_strater
That little icon is a push-pin.  It indicates that this sketch is fully constrained.
As for the sketch colors, it depends on the environment you use.  For the "Grey Room" environment, which I use, these are the colors:
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
in reply to: jeff_strater
Thanks. That's exactly what I needed to know.
