Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Red Mark on sketch in browser
What does the red mark on the sketch mean? It disappears when I remove a dimmension, but without that dimmension I believe the sketch is underconstrained (some of the lines are colored blue).   I have the preview feature "color sketch geometry based on constraint status" turned on.
See the attached screen shot for the red mark:
Also, are the colors that the constraint coloring uses documented anywhere?
Thanks.
    --- Carl
jeff_strater
That little icon is a push-pin.  It indicates that this sketch is fully constrained.
As for the sketch colors, it depends on the environment you use.  For the "Grey Room" environment, which I use, these are the colors:
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Thanks. That's exactly what I needed to know.
