- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello!
I'm trying to recreate the 40mm tall Assortment Box by Alexandre Chappel using parameters so I can create a custom shape (that isn't a standard '1x1' or '2x1' shape). I can get most of the box structure made but I struggle to get the "lip" at the top developed as a sweep tool gives me an error about the operation intersecting itself and I'm not having success with other methods of recreating it (fillets don't get the same result and the shell function produces weird results with angles on sweeping corners).
Has anyone solved this problem before?
The STL model shows off some of the funky design decisions on the boxes (including a 0.5 degree angle on the outer surface), which is easy enough to model in, but the lip has me completely stuck.
I've uploaded what I've achieved thus far - but the sketches are ugly and not at the exact measurements as I've been throwing all sorts of cutouts at the problem to try and get one to work (and I've deleted my shell operations)
Thank you.
