Fusion 360 Render Blurry
ThePieMonster
ThePieMonster
Trying to render a part and getting these blurry results. Any suggestions?
Environment: Rim Highlight
OceanHydroAU
You get more help if you can share the part.
TrippyLighting
Either turn the "depth of field" off, or set the  Blur value to 0.1 or even smaller.
This somewhat depends on the overall scale of the object/scene you are trying to render.
For smaller objects the size of a human hand, 0.1 is a good start for Blur.
Also, this is a setting you should only enable for a final shot.
