Realign an .STL with a converted body?
lalkAGGCF
lalkAGGCF
Hi all,
Is it possible to realign an STL mesh with a converted body (surface or solid) derived from it?
Lee
Haad_Ali
Hi, could you please explain your idea completely. What you actually mean by realigning the mesh or solid body.
etfrench
You can use the Mesh workspace to create a three point plane.  Create a sketch on the plane with at least one point.  Use that point as a joint origin.  Note: The stl and the sketch must be in the same component.  The derived bodies must be in a different component.
ETFrench
