- Mute
- Permalink
- Report
Hello Fusion 360 forum!
I'm confused about how to read the 2d drawing that I've attached. I want
to make a Fusion 360 model in order to do a 3d print.
The drawing shows 3 stair steps, of what is called an "Input Board" or "Keyboard"(minus the actual keys-holes are for the key shafts).
My questions are about the cutaway view labeled "Section A-A". Is that section saying that
the stair stepping is only "3mm" thick (I got that dimension from "Detail D") and that there are
two solid vertical panels, on each end of the entire keyboard, or is the entire keyboard solid?
See attachment for the Keyboard drawing:
Gary
