Re: Generative Design stuck at Processing stage
joachijs
Message 1 of 13
joachijs
Yes sorry, I sm working in Fusion 360.
Replies (12)
Message 2 of 13
dsouzasujay
Hi @joachijs ,
Thanks for the clarification. At the moment, there isn’t enough information in the post for us to investigate or assist further.
If you’re experiencing an issue where Generative Design is stuck at the “Processing” stage, could you please share more details? In particular, it would be very helpful if you could:
  • Attach the design/dataset you’re using (exported as a .f3d or .f3z file)
  • Briefly describe the Generative Design setup (loads, constraints, materials, objectives)
  • Let us know whether this happens with all designs or only a specific one
With the dataset, we can try running the study on our side to see whether the issue is related to the setup, the solver, or something else.
Once you share those details, we’ll be happy to take a closer look and help you move forward.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 13
joachijs
I understand.
The setups are quite simple, with only two fixed surfaces and in the relevant study only one load applied.
The material is a custom material, but has worked fine before without any issues.
I now have two designs where the program fails to identify that the solver is finished, and I am therefore stuck waiting on one of the outcomes. This is one of 7 outcomes, with the only difference being that the stuck process is for additive manufacturing with overhang constraint in the -Z direction. Study 2 fails to start as it is waiting for the solution to Study 1 in the picture.
It is worth noting that I have experience in GD from Fusion and other solvers, and I have been using this material and setup for more advanced simulations without any issue.
Best,
Joachim
Message 4 of 13
dsouzasujay
Hi @joachijs ,
I was able to solve the Generative Design study without any issues.
I saw you have added a symmetry plane, i had to delete the Symmetry plane to solve the study.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 13
joachijs
The symmetry plane should not hinder only one outcome?
In addition to this, I cannot proceed as the solver is stuck. As mentioned earlier, Fusion think that the outcome is still processing, but when opening that outcome it displays as finished.
Message 6 of 13
joachijs
I unfortunately still cannot use GD because of this issue. Do you need any more information from me?
Message 7 of 13
dsouzasujay
Hi @joachijs ,
Recently we did some changes and fixed the problem for many users, can you please try again and see if you are able to solve the study?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 8 of 13
joachijs
Unfortunately I have the same issue.
Message 9 of 13
dsouzasujay
Hi @joachijs ,
Could you please share us the diagnostic log Files?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 10 of 13
joachijs
Yes of course, here they are.
Best,
Joachim S
Message 11 of 13
joachijs
Any news here?
Message 12 of 13
dsouzasujay
Apologies for the delay.
I have created an internal ticket ACPSUPPORT-745 to fix the problem. i see there is a problem in our backend.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 13 of 13
dsouzasujay
Hi @joachijs ,
We have fixed the problem, Can you please give a try solving the study?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
