re-centering sketch
re-centering sketch
dj13sanz
re-centering sketch
dj13sanz
Newbie here with newbie question.
While moving along with my project I did not realize that using the "dimension" tool could mess up the size of some lines if not properly located. So way too late I found about it and now that I resized my lines (the pentagon in the image) I need to get the whole sketch back to the center ( basically each corner in the pentagon to align inside the circle in the image)
I tried many tools but as newb, I still can't get it right without messing the whole sketch.
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the post
günther
dj13sanz
It seems "Move/point to point" got me there after creating another pentagon inside the circle with my desired dimensions...Thanks
jhackney1972
You are new to the Forum so I will point out a couple of things.  When you reply to a Forum poster, do not use Quick Reply since this addresses your message to yourself, not to the person who you are addressing.  Use the Reply icon on the Forum post you are responding to.
Second, you indicate that you have solved your posted issue yourself.  This means YOU need to take your question "off of the Forum board" by marking it as solved.  This is done by you by selecting the Accept Solution icon at the bottom of the post that solved your issue.  In this case it was you.  I have done it for you this time.  You may want to read why accepting solutions is so important.
John Hackney, Retired
dj13sanz
got it. Thanks
