Radius sheet metal with taper sizes not flattening.
jasonlthornton
jasonlthornton
I'm trying to cut a profile from a radius plate. I was able to do this with straight sides by creating a cylinder, converting to sheet metal, make the cut profile into a body, splitting the face using the profile body as a splitting tool, and negatively pressing the area I don't want by one thickness. This worked no problem.
I was asked to update the profile and taper the profile sides. I used the same method and the thickness looks good on the part but when I go to flatten it gets a computation error. Is there a better way to do this?
HughesTooling
Not 100% sure why but with the taper the side of the part are not flat but must have a small twist. You can see this if you right click on the face, there's no option to create a sketch or plane.
I modified your design and added a small tag on one end without a taper, you can make this smaller than I have here. I then extruded a small flat to use as the stationary face for the flat pattern. Again you can make these very small after setting it up.
And flat pattern.
Mark Hughes
Owner, Hughes Tooling
jasonlthornton
That fixed it! I was thinking there had to be a twist or bevel somewhere to cause the issue, but the taper was too light to find it.
