- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
"SEE ATT"
I suppose this is not a bug and has to do with the components coordinate system and transformation of movement from local to global CS. It is also present when using the "joint" command. But when I have to redo and correct this action more times a day, anger grows and some forum action is needed.
This component on the picture has been rotated and now when I move it in Y global the Z distance grows. (this happens also when using "joint" command)
So the visual clue ( global coordinate system) is not in sync with the arrows and distances the user can move.
A good way to solve this problem would be to name the axes/handles/arrows/planes that the user can click and move.
Please make this usable, this is "core functionality" (that means it doesn't need a post in the Ideastation but immediate action) and personally, it drives me crazy.
Best regards,
Dean
