11:16 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a rotary lock in my model (STEP file from McMaster) and I am trying to use the joint command to place the lock onto bolts that I already have in place. The issue is whenever I select the lock(which is made up of a series of bodies) and "joint" the rotary lock joins to itself. My CAD experience is in AutoCAD so I feel like I want a group command to lock the rotary lock together but I am not sure if that is possible. I want to move the different bodies of the lock together using the joint command to line up the lock with the bolts already in my model.
Any help would be fantastic. Thanks
