"Get latest" not there when I right-click
Noah_Katz
Message 1 of 8
Noah_Katz
I'm working on this Assembly lesson:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-5687460A-8A93-4D58-A128-0D071CA2428E
I've gone through Steps 8 - 12, several times, and as instructed I added the joint in the lever file, saved the file, and went back to the Clamps Joints file, but when I right-click on the lever component, "Get latest" is not there.
I thought it might be a naming conflict; I noticed that in the lever file there was a joint9, as well as a joint9 in the Clamps Joints file, so I renamed the one in the lever file to joints10 and saved it again.
That didn't help; still no "Get latest".
Replies (7)
Message 2 of 8
josef.kucera
Hi Noah,
here is what I did and got Get Latest to work:
Hope it helps:
Josef
Josef Kucera
Fusion QA
Message 3 of 8
Noah_Katz
Hi Josef,
Thanks for taking the time to make the nice screencast, but I find it very difficult to follow them; everything is small and I have trouble keeping my eye on the cursor.
I have to keep pausing and going back to see what happened, at which point I give up and start searching for video tutorials with narration.
But after having a problem with not having the option to "Insert into current design", I suspect the cause is the same and the solution would be to copy all of the relevant designs into my own project - is that correct?
Message 4 of 8
josef.kucera
Hi Noah,
I am sorry that the video wasn't so helpful for you. But you are right the right way is to save all sample files to you project/folder since they are read only and then insert them to an assembly...
Btw, you can expand video to fullscreen for better readability.
Hope it helps.
Josef
Josef Kucera
Fusion QA
Message 5 of 8
Noah_Katz
Expanding helps a lot; I didn't think I could at first, but after several clicks it works.
Thanks, Josef.
Message 6 of 8
josef.kucera
Great to hear that I could help.
Josef
Josef Kucera
Fusion QA
Message 7 of 8
josef.kucera
Here is also nice video about assembly modeling: https://www.youtube.com/watch?v=SesuUThyZsU
Josef
Josef Kucera
Fusion QA
Message 8 of 8
Noah_Katz
Thanks, I've seen that, it's a good one
