Lofting
Lofting
Lofting
Hi everyone,
I want to make a transition duct using lofting. I can loft the shape I want as a solid but can't figure out how to hollow it out so it is hollow with a 2mm wall. Thanks.
Kim Hopkins
Oceanconcepts
The Shell command should be what you want, under the modify menu. Select open faces and define the thickness you want.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-BD394AD0-D18B-4664-B770-4CEFBC11BFD2
- Ron
Mostly Mac- currently M1 MacBook Pro
Thanks - everything worked very well.
Kim Hopkins
