"GENERATE" button
"GENERATE" button
Message 1 of 12
"GENERATE" button
Hi, guys!
I am using trial version Fusion 360 and I didn't see the "GENERATE" button is the work space! ((
That's why Im using trial or Im stupid?
Thanks for reply
Replies (11)
Message 2 of 12
TrippyLighting
Generative design is only available for subscription members.
Message 3 of 12
MikeSmell_ADSK
Hi @Anonymous -
The Generate button you were used to seeing in the Model workspace is obsolete as of the October 15th update and Generative Design is an actual workspace in Fusion 360. You should be able to find it there.
Hi @TrippyLighting -
As of the October 15th update, we have made Generative Design available for trial users and have increased the number of available trial credits to 300. The 30 day duration remains the same.
Mike Smell - Product Manager - Fusion 360 | Generative Design and Simulation
Message 4 of 12
TrippyLighting
Thanks for the clarification! I was not aware of that.
Message 5 of 12
Can you help me? Will be this option In Mac full version?
Message 6 of 12
MikeSmell_ADSK
@Anonymous
Yes, the Generative Design workspace is now available in Fusion 360 for both Windows and Mac for commercial and trial users. https://www.autodesk.com/products/fusion-360/blog/october-15-2018-product-update-whats-new/
If you are not seeing the workspace, then likely you are either not a commercial subscriber, or are on a trial license that was created before October 15th. Generative Design is not currently available for startup and education license types.
Please confirm your license type by posting a screen shot of the Fusion 360 Help>About Box.
Mike Smell
Message 7 of 12
Could you please, send me screenshot...? I cant find it! ((
In which menu category I must search it? Thanks!
Message 8 of 12
HughesTooling
@Anonymous Have you enabled the workspace in preferences? Click your name top right of screen, open preferences and select Preview then enable the workspace.
Mark
Edit. The info above might be wrong, although I've not enabled the workspace in my preferences it still shows on the workspace dropdown top left of screen.
Mark Hughes
Owner, Hughes Tooling
Message 9 of 12
And where is "Ultimate" ?
Is it the same that Fusion full vertion?
Message 10 of 12
HughesTooling
As long as you stated your trial after October there's only one version.
See info here.
https://forums.autodesk.com/t5/fusion-360-support/announcement-fusion-360-tier-consolidation-what-do...
Mark
Mark Hughes
Message 11 of 12
I have made that you told me but didt have a result(
anyway, last question - if I'll buy full version, will I get "generative design" options?
Message 12 of 12
MikeSmell_ADSK
@Anonymous
If you are still not seeing the workspace, I am guessing your are either on a startup license or and EDU license, as a trial started before October 15th would have expired.
To answer your last question, yes, purchasing a subscription to Fusion 360 will give you access to Generative Design. I will also point out that while you will have access to Generative Design, the generating and downloading of outcomes cost cloud credits, so you will need to purchase cloud credits, as well. To learn more about the costs of Generative Design, please read the following. http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-EB3D2326-6BBC-404E-91BF-AF6601E15606
Mike Smell
