Quickly create multiple mesh section sketches?
bbtfabrications
bbtfabrications
I often use scanned mesh data to create surfaces to then cut weird surfaces onto my solid models.  I was wondering if there was a quicker way to put a bunch of mesh section sketches on my mesh?  It's no big deal doing a couple but if I have to lay down a sketch every inch over several feet it gets very time consuming.
Alternatively if you know of a software that is better at creating solids using a mesh as a reference please let me know.
Thanks in advance.
Nate Schaub
CAD Designer/Machinist
BBT Fabrications
etfrench
Try splitting the mesh with a pattern of planes. Convert each section to solid.
ETFrench
koraybirand
I had the same question and bumped into yours. Did you get a better solution
Koray Birand
http://www.koraybirand.co,uk
etfrench
You can use the API to create planes: Fusion Help | Construction Plane API Sample | Autodesk
ETFrench
johnsonshiue
Hi! I agree with @etfrench. It is better to convert the mesh to Brep body before creating the sections and the sketches. Even if you may cut the mesh and create the sections. The geometry is necessarily complicated. More than likely the sketches would be too complicated to be used in modeling features.
Many thanks!
Software Test Engineer
heather_tracy
Hello @bbtfabrications,
Did the information provided by @etfrench and @johnsonshiue help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Heather | Community Manager
