how to close the surface
alexanderhermann83
alexanderhermann83
I'm designing an impeller and stuck on closing this surface:
I think I have all the lines needed to close this surface, but I can't find the correct feature.
Should I use Sweep or loft, somebody has an idea?
TheCADWhisperer
@alexanderhermann83
Loft
SaeedHamza
You'll need to loft this, and there are 2 ways to do so depending on which curves are rails and which are profiles.
The most important thing to note is that in either case of both loft options you'll need to make sure that these edges (marked red) are separate and not a single edge connected at the green point to the right, for example if you try lofting the green curve to the left with the green point to the right, you'll need to make sure that the red edges are actually separated and not a single continuous edge.
Saeed Hamza
alexanderhermann83
Hi Saeed, thanks a lot for your solution, that helps me to finish my work 👍
alexanderhermann83
sorry, couldn't share the project, because a customers part is inside, but thanks a lot for your promt reply 👍
