Quickly aligning a sketch object to origin
- Mute
- Permalink
- Report
I'm curious if there is a quicker way to align an sketch object to origin, the object is not square or rectangle and I don't have a point in the corner.
I need to do this for each DXF I import as always the DXF drawing is not placed close to the origin point because the client exports just a small part of their drawing, and each time the drawing I import is in a different position.
So in this case I had to draw a point in the corner of the drawing, it wasn't to hard as I had 2 straight perpendicular lines, but sometimes the shape is not perpendicular or straight at all.
What is the quickest way to align the drawing to the origin? (In Cambam, a software that I used a lot, it's very easy as I just select the drawing , press ALIGN and insert 0 for each axis, this moves the drawing to the origin, no need to drag the drawing or make new points)
Also if I could see the imaginary corner points I see when I set the stock in the CAM module, that would be easier as I won't need to draw any new point, but it seems the corner points only show up when setting the model position relative to the chosen stock.
Here is a photo with my drawing, the point I had to create to be able to quickly align the part using POINT OT POINT option.
