Questions during the drawing process
3088183712
Message 1 of 19
3088183712
In the red circle part of the picture, how can we remove the black line in the middle and combine them?
Replies (18)
Message 2 of 19
g-andresen
please share the file for reply
file > export > save as f3d on local drive > attach to post
günther
Message 3 of 19
TheCADWhisperer
@3088183712
Are all of your sketches fully defined?
With the Measure tool set at highest precision select two side by side faces (one on each side of the line) - does the measurement show zero offset and zero angle? If no, then the faces are not coplanar.  There is an error in your sketching.
Are there any blue lines in your sketches (rather than black)?
Message 4 of 19
3088183712
There are no blue lines.
Message 5 of 19
3088183712
Has been shared
Message 6 of 19
3088183712
This place has been cut by the construction plane
Message 7 of 19
TheCADWhisperer
@3088183712
Combine - Join these two bodies.
Message 8 of 19
3088183712
This place was divided before, but now I want to combine them together
Message 9 of 19
TheCADWhisperer
@3088183712
What color are these lines on your screen?
Message 10 of 19
TheCADWhisperer
@3088183712
Are there any unresolved issues highlighted in yellow or red on your Timeline?
Does Ctrl b (CMD b on Mac) return a list of warnings and errors?
Move is almost always the wrong move as used by beginners.
Message 11 of 19
3088183712
Message 12 of 19
3088183712
Sorry, I thought you meant whether there was a blue line on the entity. I'm sorry
Message 13 of 19
3088183712
Message 14 of 19
3088183712
Message 15 of 19
3088183712
Thank you. I have found a way now
Message 16 of 19
TheCADWhisperer
@3088183712
What are you attempting to model?
Do have a picture of something similar that already exists in the real world?
Message 17 of 19
johnsonshiue
Hi! Split19 is the feature splitting the faces. You may just suppress or delete it.
Many thanks!
Software Test Engineer
Message 18 of 19
3088183712
 A support for a conveyor belt, which I use to complete my small electronic project
Message 19 of 19
3088183712
非常感谢
