Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Question about function inside dimensions
3 REPLIES 3
alan101303
267 Views, 3 Replies
Hi, I was sketching and I needed to put "sqrt(roofExtention^2*2)" as the dimension of a line. The problem is that fusion won't allow me to do so because the function remains red. "roofExtention" is a User Parameter set to 15 centimeters. Does anyone know why I can't do this?
Tags (1)
3 REPLIES 3
daniel_lyall
in reply to: alan101303
roofExtention needs to be set to no units like kk below gg fail.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
jeff_strater
@daniel_lyall is correct - it's a units problem.  Dimensions have to evaluate to a set of unit that are in length units (mm, in, ft, etc).  The square in there is applied to the distance, too, resulting in "square mm", so the other way to get there is to divide by "1 mm" (or whatever units you are using), so that the result is in mm (or whatever).
Jeff Strater
Engineering Director
g-andresen
I would like to refer here once to a contribution (#5) by @TheCADWhisperer  in this thread.
günther
