- Mute
- Permalink
- Report
Watched this excellent video http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2016/fusion-360/pd19577#chapter=0
and have a couple of questions:
1) Re bodies vs. components, it said
- If you know the model will be a part start by creating a component
- If you are exploring a design use bodies
Some elaboration on that would be helpful, as quite often I know it will be a part but want to explore its design possibilities
2) A bit before the 50:00 minute mark, using a crankshaft assembly w/piston/connecting rod subassemblies, it was shown how adding a revolute constraint between one of the piston's wrist pin holes and the matching hole in the connecting rod added the constraint to the other piston/connecting rod subassembly.
One thing I noticed is that the top level asy was activated; is it correct to conclude that joints don't belong to any particular (sub)assembly, just to the component(s) they share?
Also, I was hoping to see what happened when a joint between the big end of the rod and the crank journal was created.
Presumably since the joint would contain a component outside of the piston/rod subassembly, it wouldn't try to duplicate it on the other instance - right?
