pythaogras on Parameters? sqrt. i dont get it .. again!
Alexrose1942
Alexrose1942
Hello
how do I calculate this: x=3mm y=5mm now i want to know sqrt(3^2+5^2), i know there's units issue and i was trying to solve it by dividing it to 1 and multiply by 1 again, but i still get the error.
I'm trying to get the sqrt of (Woodthickness^2)+(AxisLength^2)
hope i was clear
Thank you!
rohit.bapat
Hello @Alexrose1942
I will recommend using a combination of Unit Parameter (1mm) and parameters with No Units. Following is the parameters table I came up with.
I hope this will be helpful.
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Product Owner
HughesTooling
You can write it like this sqrt((Woodthickness/mm)^2 +(AxisLength/mm)^2 ) units in the parameter set to mm.
Mark
Edit just noticed * 1mm is automatically added when you press enter.
Mark Hughes
Owner, Hughes Tooling
Alexrose1942
@HughesTooling thanks, that's a simple solution that works. I don't get why the power (^) needs to be outside the parenthesis.
HughesTooling
I think it because you'd end up with square mm so you need to make the parameter unitless first. For example (2mm^2)/(mm*mm) works because dividing by (mm*mm) converts back to mm from the square mm created by 2mm^2.
Mark
Mark Hughes
joscha.wagner
Observer
Observer
But doesn't https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20 say sqrt() can do any unit and will return unit^1/2? ist this just a Bug that is not fixed yet and if so when will it be fixed or is this expected behaviour and the support document is wrong.
