Copy Sketch / Component
docara
docara
Hello Everyone,
I'm trying to have multiple designs / options for a Vee Pulley I am working on.
How do I copy the unchanging base sketch to different locations (component)
It would be nice if you could move / copy items from the browser tree!!!
Matt
erik
You can edit a sketch, select the entities to copy and press crtl C.
Then edit a the destination sketch and press crtl V.
I don't know if this solves your question, otherwise please elaborate 🙂
- Erik
docara
Hi Erik,
Thanks for the reply.
Yeah that works - I was trying to click on the sketch in the browser tree and copy from there
I didn't realise that F360 made you walk around the houses for something basic like this LOL
Matt
erik
I am glad that it solved your problem
Not everything in Fusion works the way one would think, but the Fusion team usually has a good reason for doing it the way it is.
- Erik
- Erik
I tried this, and it didn't work. IT only moved the items.
atherisinnovations
@Anonymous:
There are two other threads about this exact thing from within the last week. I realize this response is based on your search, but there are newer threads that answered this question, as this thread is from last december..
Anyways, here is what I wrote in response to the other two threads:
@epic41 wrote:
"If you turn off 'Capture Design History' in the lower right-hand corner of the screen you can copy and paste entire sketches..
..otherwise, with only the sketch you want to copy visible, you need to click-drag over to select the objects you want copied and then right-click and select copy. Then, hide the old sketch, activate the proper component, select the proper plane, start a new sketch, and paste. You should see all the objects populate your new sketch.
I haven't had to do that process for a while so someone please correct me if I am inaccurate.
There are some (special) features that are only available when design history is off, but then you don't have a design history.."
That is from here and here, two recent threads on copy/paste..
