Move/Copy
Move/Copy
kmcgheeCMFPG
Message 1 of 12
Move/Copy
kmcgheeCMFPG
So yah, I am starting to pull my hair out. I am finding the learning curve from Rhino to Fusion is harder than I thought it would be. Specifically I am trying to use the Move/copy command to do just that move sketch objects around and don't quite get some of the options, also how do you copy with it? I see not copy options, seems weird to call it move/copy if it can't copy.
I have watched many a youtube video and have found nothing that explains all the options within the move/copy command. Is it possible that someone could create a tutorial on the move/copy command?
Replies (11)
Message 2 of 12
SaeedHamza
This is a screencast I made for you, please let me know if you have any questions
Regards
Saeed
Saeed Hamza
Message 3 of 12
kmcgheeCMFPG
Thanks, that does help alot
Message 4 of 12
How can I copy when there is no "Create Copy" box to check?
Message 5 of 12
SaeedHamza
Ctrl C
Ctrl V
Saeed Hamza
Message 6 of 12
Oh, I see.
1. Highlight the sketch object
2. Ctrl-C
3. Ctrl-V
The Move/Copy window should now appear.  Thanks Saeed.  🙂
Message 7 of 12
atherisinnovations
@Anonymous:
 Hi, I posted this as a response to a similar question, I think it applies in your case.
https://forums.autodesk.com/t5/fusion-360-design-validate/while-sketching-is-the-quot-copy-quot-element-of-the-move-copy/m-p/7982570#M157756
@atherisinnovations wrote:
If you turn off 'Capture Design History' in the lower right-hand corner of the screen you can copy and paste entire sketches..
..otherwise, with only the sketch you want to copy visible, you need to click-drag over to select the objects you want copied and then right-click and select copy. Then, hide the old sketch, activate the proper component, select the proper plane, start a new sketch, and paste. You should see all the objects populate your new sketch.
I haven't had to do that process for a while so someone please correct me if I am inaccurate.
There are some (special) features that are only available when design history is off, but then you don't have a design history..
Message 8 of 12
Thanks Epic41!
Message 9 of 12
TrippyLighting
Most Fusion 360 users want to do parametric design and for those, turing off the timeline is not such a good idea.
Message 10 of 12
atherisinnovations
@TrippyLighting:
I can see that, if it is really important to maintain design history there is really no way to copy the sheet aside from just copy/pasting the contents in the sheet, and that's not so bad really. I still would prefer a 'sketch library' and 'cam library' feature because I re-use alot of the same sketches and cam setups in many different projects..
But back to the issue at hand, one can always save a copy of the design file before turning off 'capture design history', to be safe, just use 'save as..'
Message 11 of 12
TrippyLighting
 ...I still would prefer a 'sketch library' and 'cam library' feature because I re-use alot of the same sketches and cam setups in many different projects..
Yes, the ability to re-use sketches would really be nice and very helpful.
Message 12 of 12
etfrench
You can copy entire sketches by putting them in a component, then copying the component.
ETFrench
