Message 1 of 13
Projection of sketch entities problem
03:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi-
I'm having an issue that I can't seem to figure out regarding projecting sketch geometry from one component onto a sketch of another component.
I'm making an adapter plate that mates a servo motor with a gear box of a different size.
With the adapter component activated, I select a face of the adapter plate as the sketch plane, then I select the mount holes of the gearbox thus projecting the hole points onto the sketch plane of the adapter plate.
In theory if I move the gearbox, say rotating it 10 degrees, the sketch entities on the adapter plate should move too, since they are projected from the gearbox
What am I missing here?
Screencast attached
Matt
