I'm trying to create a 2mm thick "fairing" body, over the top of two other bodies - the hull and cross beam of a catamaran. The background to this is probably better explained in another post, Create Fairing Between Two Bodies.
To recap from there:
My plan is as follows:
- Create a thin (2mm) body on the top of the curved cross beam. For this I made copies of the sketches with the 2 profiles used for lofting in that area, and cut away the parts of the curves I didn't need. Then I created a vertical 2mm face from the 2 resultant curves which I used for a Loft.
- Use the same technique forward of the beam on the hull to create a new face there, and then loft from the "beam body" to this new face, using some shaped rails.
- So the same on the aft side of the beam to the hull again.
- Side piece from beam to hull.
- Add in the missing fairing sections
I've managed to do Fairing Bodies 1a and 1b. These were relatively simple, as the existing Beam Body they "cover" has convenient profiles from which the body was Lofted.
I made copies of those profiles in new sketches on the same planes, cut away the curve parts I didn't want, then used Sweep to provide new "surface" bodies - these gave me the profiles for a Loft. Here they are, moved up off the Beam Body:
Now I'm trying to do Fairing Body 2 as shown in my diagram. To do that I need an accurate curve of the top of the Hull Body, from which I can do a sweep to create the 2mm thick profile, which I hope to then Loft with the edge of Fairing Body 1a. With the help of a number of Rails.
