Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Been working on this model and have been using the Project->Intersection to create sketch objects from the body of this component. It was all working just fine but now when I try to project onto a plane that is 1/2" in front of the body i am not getting any results and no errors or warnings.
I have the offset construction plane selected, then hit "new sketch", then Project->Intersection, then I select the only body within the component and hit ok. As you can see in my model i was able to do this on a plane flush with the parts outer face that I'm trying to project.
What am I doing wrong?
